little blue lines that move up and downn?
Stickygreen
Post by Stickygreen »
SO i just noticed after about 2 years using Resolume there are little blue lines next to the clip bank, just after the controls end. these blue lines seem to move with some sort of sequence..? maybe music in the clips..? i never use audio so i don't know if this is the case, just saw it, and wanted to know what it is? anyone know what I'm talking about?
Re: little blue lines that move up and downn?
These are indeed the audio levels of the clip playing in that layer.
Stickygreen
Thanks for the answer Goto10,
I just bought some clips from you guys, "Invader series" some of them have audio, that's where I first noticed it.. shows you how often I buy other peoples clips....
edwin
Post by edwin »
Stickygreen wrote: I just bought some clips from you guys, "Invader series" some of them have audio, that's where I first noticed it.. shows you how often I buy other peoples clips....
Hmmm, that's odd, they shouldn't contain an audio track. Does the clip panel show info about the audio track, you can delete the audio track because it's just overkill and probably just contains silence.
Basic
Post by Basic »
could you hear anything when playing the clips?
GeeEs
Post by GeeEs »
When you replace a videoclip on a spot where a videoclip with seperated audioclip was before, it will only replace the videoclip! Audio will stay. So you really have to "clear" the spot before replacing with a new videoclip!
