is there a way to delete the cue points for a clip?
if i need to copy the clip, do i need to replace all the cue points to prevent double triggering when using midi?
delete cue point
Re: delete cue point
Right click on the 'set cue point' button
To be complete in this: mappings done in Application midi map on the clip properties are context dependent, so they will only trigger cue points on the active clip. Mappings done in Composition map are tied to the clip, so they could potentially trigger two cue points on two different clips. Hope that makes sense somehow
thanks
yeah that makes a lot of sense. ive ( finaly ) got it into the studio in the last week with a producer friend creating an a/v set and am now appreciating the composition mapping a lot more ( i normaly use application mapping for vjing ) so theres likely to be more stupid questions than usual coming from me over the next few weeks
