i am dealing with a quite strange situation -
i control the size of different objects (qc-file) in resolume via an alesis performacepad.
in the screenshot you can see that even if the note comes out "clear" - only 1/c2 is played -
resolume affects another slider which is set to react only on 1/a1..
anyone knows this kind of problem?
best -
td
edit - the screenshot is cut off - you might rightclick to display the image.. sry.
