extreme FPS dropdown
VJVertex
Post by VJVertex »
while testing midi aso. i had another very mysterious effect.
Some combinations of files let the FPS drop to 0.9 - 1,5, but with other files or alone it´s no problem.
very mysterious is one file, if i play alone it i have ~1 FPS, but if i start another or start to preview anything i have normal FPS (25 - 50), crazy!
| EVGA SR-2 | 2 x Intel Core i7 X5650 | 48 GB Corsiar DDR3 PC12800 | 2 x HD5870 Eyefinity 6 | 1 x GTX580 | 256GB Samsung 840 PRO | 160GB Intel Postville | Win 7 X64 | Resolume Arena 4 |
Tschoepler
Re: extreme FPS dropdown
Post by Tschoepler »
upload the file! or send it to resolume support :idea:
yes...I would also like to test your clip....
Here u can upload your clip... http://uploaded.to/ its a fastfilehoster!
greetz
Thanks for your feedback on the beta, VJVertex.
If you want to help us fix any problems you're having, it's best to send us the log files and clear steps on how to recreate your issues. So in this case it's important in which order you load and trigger the files, and if you can recreate this starting from a fresh composition. Also we'd need the video files of course!
VJVertex
Post by VJVertex »
no problem, i´ll try and send the file(s) and the log(s).
hope i can help. :D
