Hi everyone,
I'm wondering what the simplest and best way is to manipulate a video feed coming from a Macbook Pro's display port and feeding it into another laptop for manipulation with Resolume.
I'm going to be using 2 laptops:
- 1 Macbook Pro is generating some video signals using an infrared camera setup programmed in "Processing"
- 1 Windows 7 laptop is going to be manipulating that signal using Resolume
I'm trying to find some kind of USB device that takes a display port/vga signal and can translate that into a video-in feed which will show up as a USB camera on the PC running resolume.
I appreciate any suggestions or help I can get!
2 Laptops 1 Resolume (Mixing a feed)
Re: 2 Laptops 1 Resolume (Mixing a feed)
Blackmagic is what you are looking for...
For Example:
http://www.blackmagicdesign.com/products/intensity/
but if you only have USB 2.0 then I'm not sure about the performance...
maby some one else can answer about this.
/Stafis
For Example:
/Stafis
