Group Select duration edit not present.
When a group of stills, sources or other things having durration are selected, durration is not avalible for common edit. Is there another way to, by layer, change the autopilot speed of a series of sources or stills? For 200 pics, changing each one is a pain.
Re: Group Select duration edit not present.
At the moment, this is not possible. If you're not scared of a little hacking, it's relatively straightforward to edit the .avc file.
Ok, so looking at the default.avc... Is there a map? I'll go searching. There are lots of 5000's in that file.
