Loop on Frame X
Intange
Loop on Frame X
Post by Intange »
I create content that builds in and then on frame x it is a perfect loop to the end. This is a feature that exists in D3 and it would be great to have in Resolume.
Online
Re: Loop on Frame X
For now, duplicate your clip, in the same layer, so they follow each other, set first clip to auto pilot to second clip, and cut second clip with the in/out markers, so it only has the loop, and set it to loop.
Make sure layer transition is set to 0, launch clip1.
Intange
Re: Loop on Frame X
Post by Intange »
Can you be frame accurate on the time markers? Sorry im not sitting in front of Resolume right now.
Online
Re: Loop on Frame X
Intange wrote: Fri Jan 24, 2020 17:01 Can you be frame accurate on the time markers? Sorry im not sitting in front of Resolume right now.
Yes, you can.
