Resolume 4.1.9 Update: Sweating the Small Things
Mulky
Re: Resolume 4.1.9 Update: Sweating the Small Things
Post by Mulky »
Very happy about the alpha transition fix. Nice one.
anachphronism/neologasm.
manuelgazzo
Post by manuelgazzo »
AWESOME!!!
once again, thank you very much!!
philthehorror
Post by philthehorror »
Cool update. I'm noticing that my sfFreeframe plug-ins are no longer popping up. I placed them into the new vfx folder. Any ideas?
Sadler
Post by Sadler »
Make sure you copy
fmodex.dll
fmodexL.dll
FreeImage.dll
FreeType-6.dll
Zlib.dll
from your previous Resolume root to the 4.1.9 root to get the sf FFGLs to load.
thedawjones
Post by thedawjones »
"FIXED: [CRASH] Selecting a buffer size of 64 or lower gives spinning wheel of death on Maverdicks. :lol:
Intent or Freudian slip?
Love the clip scrolling.
Thanks dudes.
Sadler
Post by Sadler »
lotech wrote:Not a bug report but still a request to see in the next version -
NEW: Installer now offers to copy fx and presets from previous installed version.
A small tip for those who find this onerous: copy all your 3rd party FFGLs to another directory and then link that directory in Resolume/Preferences/Video/Plugins.
Doesn't sort out your presets though and you still have to link the directory but good for updating plugins across installs and getting set up quick on a new install without copying files around. Also doesn't deal with files that have to be in the Resolume root (e.g. spout) but I doubt the installer could/would want to handle these for users.
This is indeed the recommended way of working with 3rd party plugins. Personally, I make an extra folder for them in the Resolume folder in Documents / My Documents.
Presets are stored in a presets subfolder in this Res docs folder, so they are already maintained between different versions.
Btw, when updating, all you have to do is trash the previous Resolume 4.x.x folder, which lives in Applications / Program Files (x86). Some people seem to use 3rd party apps for uninstalling. These apps trash every folder that has the word Resolume in it. Of course this means that you lose all your comps, presets, effects and even your registration.
francoe
Post by francoe »
I've tryed the 4.1.10 version on win7, and I found that don't allow me to load clips with non standar characters in his filename (á,é,ô, etc). On the same system, v4.1.8 load the clips without any trouble.
Then I've tryed the same version on another windows installation and worked fine, as usual.
Any tip about that?
