R4 completely busted - won't play clips!
He2neg
Re: R4 completely busted - won't play clips!
Post by He2neg »
strangehead wrote:My Composition has 7 Decks (each with about 30 png and 30-50 effects total)
Some of the decks were "closed"
Now i have open all the decks (SAVE COMP after opening a deck -> Then RE-OPEN COMP)
Since all decks are open in the Compositon, Resolume works ;) / and i can change decks without problems
I still think, that the SystemUpdates i did yesterday is my problem....
I had also some Problem with pngs. When you got the time try to convert them into .mov with DXV. I had big improvments with running stable and resources.
~Berlin~
craftycurate
Post by craftycurate »
Yes it's a Flash problem it seems.
I created a new Comp, loaded in some DXV decks from other Comps - everything works fine. As soon as a deck is loaded that contains an SWF or an SWF is dragged into a deck, all the previously reported issues happen: no master output, can't play clips, effects don't show etc.
