Save Video in equirectangular 360 format in resolume
Re: Save Video in equirectangular 360 format in resolume
When you say "export to it" what do you mean?
- AndriiShramko
Save to MOV (AVI) Video in equirectangular 360 format for editing it in the After Effect (with Mettle plugin)
If you're on a Mac, you could try streaming your comp over Syphon and recording with Syphon Recorder.
I'm not sure if your Codec will be available in the Syphon Recorder preferences but it's worth a try!
Do you want a plugin to convert a 2 fisheye video to 360?
Give me a sample video, and I might write a plugin to do the conversion when I have time.
I would be very happy to see this to : )
+1
+1
- AndriiShramko
Thanks.Oaktown wrote:If you're on a Mac, you could try streaming your comp over Syphon and recording with Syphon Recorder.
PMed to you.DanielArnett wrote:Do you want a plugin to convert a 2 fisheye video to 360?
Hi Daniel
This works :
https://github.com/yasuhirohoshino/oF-t ... ectangular
The shader could be used in a plugin. I have working code and other stuff to save you time. PM or email me.
Lynn Jarvis
This works :
Lynn Jarvis
- AndriiShramko
"This openFrameworks example convert the dual fish-eye images from RICOH THETA S to panorama images on realtime." is it possible to save this equirectangular output to AVI (mov) ?leadedge wrote:This works :
Lynn Jarvis
Not immediately. A program would need to be developed to do that.
But, by using the shader in that Openframeworks project, a freeframe plugin would convert the dual fisheye video to equirectangular and then you could use Syphon recorder to produce a movie file as noted previously, if you are using a Mac.
If am not sure why you need to do it this way if there is software for the Theta S that already produces video in equirectangular format.
Also I looked at your Resolume project, but that is not in a fisheye format so I can't see how you would produce 360 video from that. I don't quite understand what you are trying to do.
- AndriiShramko
HI!
I dont need convert the dual fisheye video to equirectangular. I need export resolume VJ video result in the equirectangular 360 video format to see it in the VR googles.
