You have a point there, before I updated (downgraded) my drivers I was only getting 30FPS when on battery and 60FPS when plugged in - which indicates something to do with screen sync.dinga wrote: Might have been a v-sync option rather than a driver issue?
Low FPS with a GTX1060
Re: Low FPS with a GTX1060
Good to know, i did change the V-Sync option now i am getting what i should. But still 30 when not plugged in and when plugged in 60.
Is your laptop switching to the integrated GPU when you're working on the battery?
How can I check that reliable. On windows that is.Oaktown wrote:Is your laptop switching to the integrated GPU when you're working on the battery?
Ok i check with the Nvidia Activity Icon, and yes on battery it is using the GPU, and arena.exe is the only app using it.
Hopping in to say I have the same problem, same video card, different laptop.
Acer Predator
i7-7700HQ @ 2.80ghz
16 GB DDR4 RAM
Windows 10 64 bit
256gb SSD, 1tb SSD
Was getting 120 frames a few weeks ago with 4 layers of HD content. Everything is DXV3. Now I'll get 60, and then when I go into advanced settings to set up my screen, it won't go above 30.
-turned off vsync, put arena in high performance mode
-right click started Arena with high performance gpu
-updated drivers
-rolled back drivers
-checked power settings
hell it even gets 30fps (after checking advanced options) with no clips selected and the test card on.
Acer Predator
i7-7700HQ @ 2.80ghz
16 GB DDR4 RAM
Windows 10 64 bit
256gb SSD, 1tb SSD
-updated drivers
What i did too to fix most of it, complete uninstall the Nvidia Driver then reinstall the current version, that fixed a lot of points for me.
Hey I have the same problem with the Aero 15. Can you explain to me how to uninstall the drivers?hive8 wrote:What i did too to fix most of it, complete uninstall the Nvidia Driver then reinstall the current version, that fixed a lot of points for me.
Is it this one? http://prntscr.com/j2a0gr
Is there another solution for the problem?
I have the problem with low fps in Minecraft. But I need the laptop for work (in Minecraft). So at the moment it's a big issue for me.
In windows go to your system settings -> Apps from there uninstall everything Nvidia reboot, then download the newest drivers and install them reboot again. Windows will supply default drivers at first but after the new install and reboot the newest drivers should be working.
Ich hoffe das Du kein problem damit hast. Falls Du noch Fragen hast lass mich wissen.
