Really no one from Resolume Crew sees this bug in Resolume? It's new version 6.0.1 and Midi still does not work property with my controller.
R6 beta works properly
R6.0.0 and 6.0.1 does not work properly
						AkaiAPC40mkII and MIDI problem in Resolume Arena 6
Re: AkaiAPC40mkII and MIDI problem in Resolume Arena 6
As I said in a previous post, we have tickets for these issues. That means we're working on them.
Hello,
I have a MIDI problem between resolume 6.0.3 and my AKAI APC 40 MKII.
When I change desktop, the controller still displays some clips while the new one is not yet selected.
More problematic again, if I decide to launch one of the clips that is still highlighted it does not fire.
I have to click on another one or use my mouse.
I have tried all possible configurations between MIDI modes but nothing helps.
Thank you in advance.
I could put some screenshots if it is not clear enough for you
To illustrate my problem
on the first desk I select one clip on 5 layers
after I select an other desk and I get this :
the clip on the third layer is persistent otherwise to be disconnected !
where is the problem ?
The feedback to the APC40 is not sent correctly.exoplanet wrote:where is the problem ?
It will be fixed in the next release.
Ok Zoltan ....  I must be patient in this case !  Thanks for your answer !
