Can you download this:
https://github.com/leadedge/Spout2
open the demo folder and run the spout sender.
This should now show up in your sources tab (it works for me)
If that isn't working, there is something up with your machine.
Arena 6 support Spout~! solved~!!!
Re: Arena 6 support Spout~! solved~!!!
Res6 updates its sources in realtime. I opened Res6, then opened the spout sender, it immediately populated my sources panel with spout sender.lovezhiqi123 wrote:Zoltán wrote:What are your machine's specs?
It works!
I have to run spout first, Then I can find spout in sources~!
Thanks a lot!!!
He was using SpoutSender.dll before. That's a plugin which is always there as a source. It just won't display anything when there's nobody sending Spout.
When you use the native Spout receivers, they don't appear until you actually start sending.
measuredincm
Hey, I have a follow-up question to this.
In RA5, I would load my plugin (a Processing sketch, with SpoutControls.dll) as a source, and when I activated it in Resolume, my sketch would begin playing (without opening an external window or the Processing environment)
In RA6, it seems like I need to have the Processing IDE open and have my sketch running.
Is this true? Any way I can get Resolume to start my sketch for me? I am worried that having multiple sketches open at once would waste resources on my machine.
