Cool trick, this defenately helps smoothen the movements. Thanks!Empyfree wrote:Another way of creating a very slow rotation of a still image is to set the rotation to follow "Clip position" and then set the clip duration to a long time. For example setting it to 60s would give you one revolution of the image per minute. 3600s gives you one revolution per hour!
Of course this is useless if you're already using the clip duration as part of an awesome "auto-pilot" system.
