Hive8 Cloner 64 bit?
hive8
Re: Hive8 Cloner 64 bit?
Post by hive8 »
Thank you big J for putting this up :)
hive8
Post by hive8 »
Hi Joris i just downloaded the code you put on Git. It compiled fine, but for some reason it does not show up in the effects panel. Should it work on 6.1.2?
The master branch on Github compiles plugins that are compatible with the upcoming Resolume OpenGL 4.1 version, which is not publicly available. We sent you a dev build of the OpenGL 4.1 version though.
hive8
Post by hive8 »
Thank you, yes i do have that DEV version :)
fred13
Post by fred13 »
Dear Joris,
I'm a begginer on Resolume but I have been quickly fall in love of this amazing software ! and indeed this effect made by Hive8 was awesome ! But I do assume that this effect is not running under 64bits.
I have no clue I should place your complete plugins, may I have your support here please ?
have a nice day
fred
Check out the new Radial and Linear Cloner effects in 6.1.3 :)
fred13
Post by fred13 »
yep !!! many thanks I will check it out tonight but I've already seen both effects :D
have a good end of the day !!!
fred
fred13
Post by fred13 »
Many thanks Joris it works perfectly 8-)
Digitrevx
Post by Digitrevx »
Joris I don't know if its equally in demand but I do love his 4-9 cloned screen plugin.
I was just looking for it today actually and I'm not sure where it went for R6. But it sure is useful when you are combining 1080p content with larger content in one composition.
