Resolume Crashing
blobe
Re: Resolume Crashing
Post by blobe »
Is there a easy way i can post that resolume log? its a pretty big file, Also the crash still happens with all of the other programs closed
Online
You can send the log file to mail@resolume.com. Please also mention this topic in the mail ;)
blobe
Post by blobe »
Does anyone have a recommendation for the nvidia driver version I should try rolling back to? Thanks
blobe
Post by blobe »
Ok, so im still getting crashes without a crash report. Resolume seems to crash 1-3 times within a 10 minute window and then work for over 4 hours with no crashes, very weird.
Where can i look in event viewer to see what may be causing reoslume to crash?
Online
Which driver version are you using now?
https://www.howtogeek.com/123646/htg-ex ... an-use-it/ should help you get to the logged windows events.
If you get a crash, note the time, and look for an entry with about the same timestamp in the Custom views, administrative events. Would be an Error level probably.
