Elgato 4k60S+
Re: Elgato 4k60S+
spout should not cause any network traffic. It's about texture sharing on the same machine directly on the GPU. So even only little performance loss.
Re: Elgato 4k60S+
Oh sweet, ill look into this route thank you.
As for when or if this gets resolved, should i just check back here or keep a eye on the new patch notes?
Re: Elgato 4k60S+
Release note should mention these kinds of fixed indeed.
Re: Elgato 4k60S+
Thank you very much. We appreciate what you guys do.
- Vjcheshire
Re: Elgato 4k60S+
Just bought a 4k60S+ USB version and it does the same thing with resolume. Green Screen with static on the top. Works in OBS and native Elgato capture software. Just seeing if there is a fix or if the OBS spout is the best work around?
Re: Elgato 4k60S+
It's still the same.Vjcheshire wrote: Thu Mar 16, 2023 21:57 Just bought a 4k60S+ USB version and it does the same thing with resolume. Green Screen with static on the top. Works in OBS and native Elgato capture software. Just seeing if there is a fix or if the OBS spout is the best work around?
FIX PLEASE! Thanks!
Re: Elgato 4k60S+
Could you please send us the Resolume log file via the feedback tab in preferences?
