[Problem is back] Wire freezes
AcdNrg
Re: [Problem is back] Wire freezes
Post by AcdNrg »
Oh btw: For what it´s worth: I can put Arena on any display without issues, even doing stupid things like preview monitor and Arena File Brower on the right display, composition monitor and effects frame on the left display and the rest on the middle display - no issues at all.
Does Wire handle frames/windows differently?
They should both behave about the same.
Could you send us your Documents/Resolume Wire/preferences/recentlayout.xml to mail@resolume.com?
Then if you remove that, Wire should start up fine again.
AcdNrg
Post by AcdNrg »
Will do. I also talked to Danny on Slack, so to avoid any doubling of tickets, can you sync with him?
What I noticed: The last time I deleted the docs folder was yesterday. Therefore, the RecentLayout.xml has a timestamp of 2022-01-06. I just tried to run Wire a moment ago (didn´t delete the settings in between) and the only file that got updated is the server.xml (2022-01-07).
Will send a zip with working and non-working RecentLayout plus the latest logs. Unfortunately, no crash reports are generated, so it seems to become unresponsive before that can be triggered.
ttyl via mail and thanks for your support!
