i guess no updates...
Low frame rate with slice effects
Re: Low frame rate with slice effects
that's sad
7.14 with no changes... so may be in 7.15 we'll finally be able to work with Slice Outline effect like it should be?
Create your own in Wire using meshes and your problems are solved. This is new to 7.14.
can you give an example how u'r creating in Wire the Slice Outline effect that's working with Bezier lines, pls?Arvol wrote: Sun Apr 09, 2023 18:56 Create your own in Wire using meshes and your problems are solved. This is new to 7.14.
Rectangle to Mesh, using Slice Info for translation. Then duplicate the previous with a float for the scale, then mask out the 2 for the outline.
if it's so easy and simple, then why KPT HIPPO's SLICE EDGE still doesn't work well in 7.14?Arvol wrote: Mon Apr 10, 2023 14:43 Rectangle to Mesh, using Slice Info for translation. Then duplicate the previous with a float for the scale, then mask out the 2 for the outline.
Couldn't tell you as I'm not that person
I wrote Tracer back in 2016 and have been working with slice outlines for a while now. I'm waiting to update Tracer to meshes because I want localized feeback (not currently possible), but I might release it now anyways and just update it when that becomes a thing. I've been able to push 100+ slices and keep my fps happy.
sounds good
that's what he wrote: Waiting for Resolume to allow to fetch polygons as meshes as well.
