No that pc is running windows 10, should i upgrade it?
We have a pioneer cdj 3000
Resolume Not changing faders from the Pioneer connection
alexandremix
fiverecords
Re: Resolume Not changing faders from the Pioneer connection
Hello, I have tried with CDJ2000NXS2 and CDJ3000 and a 900NXS2 mixer and I have the same problem in both windows 10 and windows 11 with version 7.13.0, 7.13.1 and 7.13.2 on different computers. The problem is the same, it recognizes the track name and time but not the mixer fader
The bridge app is not behaving the best on windows 11.
Do you have any other network interfaces installed or enabled?
alexandremix
No im not on windows 11
alexandremix
This issue still persists even after updating resolume to latest version.
I managed to fix the slow dj link app by deleting cache in the documents folder.
but faders are still not working.
I also tested by creating a dedicated network just for the CDJ3000 and the pc. no internet in the mix, just everything connected.
alexandremix
Re: Pioneer pro dj link compatibility
Hello I have a DJM-900NXS2
and the fader data is not working, do you know why?
How do you know that the fader data does not work?
can you elaborate on why? This is a issue that I am having for a long time and i cant discover why
The many ports listed to have opened are used to send different data from the bridge app.
The faders not working in Resolume would be issues with one of the ports.
I'd unininstall or disable all network interfaces in the device manager, which are not needed to conenct to the players, including VPN and loopback ones, and only use wired conenctions.
It's also best to switch off firewalls, and make sure the players don't receive much network traffic, like broadast Art-net.
alexandremix
Hello, this is a PC that is connected only with the CDJ3000Zoltán wrote: Thu Jun 01, 2023 17:22 The many ports listed to have opened are used to send different data from the bridge app.
all firewall is off, all antivirus stuff is completely off, theres no virtual networks or vpns just a simple network connection , On the router side all firewalls are off as well.
Everything works flawlessly only the faders are not working.
So no mixer connected to the bridge app?alexandremix wrote: Mon Jun 05, 2023 18:31 Hello, this is a PC that is connected only with the CDJ3000
Where would you expect the fader info come from then?
alexandremix
on the software it shows that 3 cdj3000 are connected and a single DJM-900NXS2 connectedZoltán wrote: Wed Jun 07, 2023 10:47So no mixer connected to the bridge app?alexandremix wrote: Mon Jun 05, 2023 18:31 Hello, this is a PC that is connected only with the CDJ3000
ill show you a print on saturday
