So you need to press "i" to go in. I guess the .tox starts at the root vs the folder I was in when I exported it.
If you see 2 green nodes you're good. Just change your audio device and setup your OSC and Audio Trigger threshold. Here's an example video of how it works:
https://drive.google.com/open?id=1W5b64 ... p=drive_fs
Show clip with microphone
booshtukka
Re: Show clip with microphone
This makes sense - thank you so much!
So I need to keep TouchDesigner running all the time for this to work? Is it low on CPU usage?
yes and yes
booshtukka
I'll try this for my next set. Thank you!
