Gofunco Prophecy 4K 2x2 Video Wall Processor
Re: Gofunco Prophecy 4K 2x2 Video Wall Processor
Correct but you will also need a Sync II card and the outputs will need to be the same resolution and refresh rate. (2) A5000's will run about $4,000 and then you need the sync card for about $2,000 in addition. You can find FX4's on Ebay for around $2,000 as well.
shafiro
Post by shafiro »
I see.
FX4 is inevitable.
Thank you for your patience Arvol.
