Resolume running in Vista
vanooijen
Post by vanooijen »
Unforunately I still have the same problem, I guess I have to get rid of Vista and install XP on my lappy:cool:
By the way does anybody know if there are external video cards through USB available? I am not talking about a monitor splitter!
Bart I hope Resolume will soon be 100% compatible, in case I ever buy a new PC with Vista pre-installed.
vanooijen
Post by vanooijen »
:P Finally I have Resolume working on my pc, it turned out that the Resolume version 2.0 was causing a lot of trouble, so I upgraded to Resolume 2.4 and now the program runs flawlessly, although I haven`t yet tried to output the 2nd display.
Thank you guys for all the good advice, it has deffinately additional value, I think all the small aspects together make a big difference.
Cheers Seb
http://www.flammablelife.com
seb@flammablelife.com
shadestar
Post by shadestar »
Just wondering if there is any news on the Vista front?
Anyone else got it working yet?
Currently looking at getting a new laptop, but the
one i'm looking at, comes vista built in.
Any advice.. Might still go ahead and get it, and just
keep my old laptop for resolume for the time being.
VjSky
Post by VjSky »
Ok, I've managed to run reslume on my home PC:
Vista Ultimate 64bit
K-Lite 64 bit driver pack
Resolume 2.41
Tripple monitor
without any problems:
http://stefans.users.sbb.co.yu/Vista%20 ... solume.jpg
Now, my suggestion is that you modify the shortcut rather than editing global windows graphical settings ( its easier and faster ):
vjcaci
Post by vjcaci »
Thanks for the tips but still struggling with 2.4 and the dreaded Vista! I've made all the suggested chages but every time I try to change the screen settings to output my images my laptop crashes.
I 've had to go back to running Resolume 1.5 but that's not really an the best option for live work.
Any new suggestions?
Manwell
Post by Manwell »
I had the same problem with my friends laptop running Vista and the 2.4 demo, every time I tried to setup an output to a tv monitor the laptop restarted itself. The laptop is a cheap model with an integrated graphics card so I downloaded the latest drivers from Intel and I was able to setup Resolume's outputs without any problems at all. That was the first and only time I have updated drivers and actually fixed a problem!
ganix
vista home premium
Post by ganix »
I know this is an old topic, but I've just signed up...
I have a new laptop that came with vista home premium ready-to-use, no installation disc and it won't let me downgrade to XP, I am experiencing a lot of the problems mentioned above, but also, when I load up I keep getting this message...
after clicking continue 6 times, resolume runs, but crashes after 3-5 minutes, often when I try to load clips which I know work with resolume on my old XP comp. (very old, very slow piece of junk hehe).
I had tried setting the display to windows classic theme, hence the old school dialouge box, anyway, if anyone can help it would be much appreciated!
thinkmassive
Post by thinkmassive »
I am running Resolume 2.41 in Vista and the only problem is no Flash support.
Please see my thread in the "Problems? Bugs? Solutions?" section:
http://www.resolume.com/forum/viewthread.php?tid=3680
projectile
Re: Resolume running in Vista
Post by projectile »
Just go a neww Vista lappy, and yep, I only one or two of the demo clips work. That must mean it's a codec thing, but I've donloaded all the codecs i had on m old machine and it's not working.
Help? Anyone? All mclips are indeo 5.1 and don't frkkin work, and I got a gig in a few days! grrr please on make me use arkaos it's crap
VJ Rick floyd
Post by VJ Rick floyd »
I recently bought a new laptop a SONY VAIO AR 61 , 2 gig of memory, 200GB harddrive, NVIDA Geforce 8400M GT GPU, Intel Core 2 Duo Processor 1.66ghz and vista.
I installed Resolume and to be fair it is running ok the only problem I have is when playing more than 2 clips at a time. It seems to run perfect with 2 clips layering over eachother but somthimes slows way down with three and even crashes.
Also I have found that a good 3 -4 clips from the demo footage do not play at all .
Any ideas what might be happening?
