Audio FFT Analysis in Resolume 3
HerrNieDa
Re: Audio FFT Analysis in Resolume 3
Post by HerrNieDa »
what i also often do with trapcode soundkeys is to f.e. multiply the output-value... woult also be nice and no problem i think... maybe like an extra speed-bar...
and maybe for that is runs smoother something using like the fall or so? maybe that there's a smoother value like the average of the last 4 beats or so...
glasshopper
Post by glasshopper »
QUESTION ... do you think this functionality will be available before the end of the year ... i have a project and would definitely consider resolume for it if the flash features are implemented ... Tx.
glasshopper
Wow - after re-reading the posts think I missed the point - Bart this is just the FFT analysis and not the introduction of the flash features isn't it ...!
VJair
Post by VJair »
the thread is called "Audio FFT Analysis in Resolume 3"
glasshopper
Yeah okay man - but when I think FFT analysis - I always associate it with Flash cos in my previous experiments with Resolume demos - that is what I was playing with ... not anything else. Flash and its FFT features are the most exciting thing for the direction of what I wish to work on where Resolume is concerned. Sorry for getting excited - getting carried away and then realising my own mistake and airing it - but the SALT feels good. Thanks.
glasshopper
In fact - quickly looking back at other posts you can see why I grouped the FFT functionality with Flash - it is quite often mentioned in the same breath by the RES developers.
Flash playback is on his way, hold tight ;-). Flash playback works quite nicely in version 2, but getting it to work in version 3 is a problem. It's halfway there but instable, so that's why it's not in. Audio FFT is also work in progress like we said so from the beginning
EDWIN
Bug fixes, Flash and Audio FFT are our main priority right now and we are working as hard as we can
BART
Bart / Edwin... could you please answer these questions... will the ability to play Flash be bundled with the FFT analysis features in the next Beta - Yes / No.
Thanks guys - keep up the good work.
