Resolume 3.1 Released: Bug Fixes & Flash Playback
Re: Resolume 3.1 Released: Bug Fixes & Flash Playback
Yeah great job guys!!!!
Really well done guys!
I have only had a couple of problems so far, posted in the feedback area.
Something strange happened with my midi mappings and I'm having to redo them all..... and I'm getting flash frames on one shot clips in bpm sync mode.....i.e when the clip ends sometimes a couple of frames from the beginning of the file make their way through.......
Macbook Pro 17" 2.93ghz, 4G Ram, OSX 10.5.7, Live 8.2.2, Avenue 3.3.1, Faderfoxes LV2,DJ2, LD2, Monome 40h.
YESSSSSSSSSSSSSSSS!!!!!!!!!!!
Thank you!!!!!!!!!!
						Thank you!!!!!!!!!!
ooooooh no! It won't load on my 64-bit Vista, even though 3.0.1 will! Any ideas????????
Thaaaanks....
I go to try it directly!...
				Luminescent drive
Hi guys!
very good!!! .. at least from what I've read..
...but.. I cant run 3.1 on my system!... the logo appears.. than the resolume window but after few seconds it crashes... Any ideas? 3.0.1 works without any problems...
Luminescent drive wrote:Hi guys!
I had this problem I think its a prob with the high pass if you remove it or replace it with the version of this filter from the previous install should fix the prob
I got it to work! I have to run it in compatability mode for Windows XP Service Pack 2....
What happened to film bleach? :\
nice nic0r guys!! at least i can use all my fav text flashs now
 waiting has been annoying sometimes, but this is really so great!! especially keystone and all the flash vars .. im still in vacation and in low testing mode. but next week ill have a gig, so we´ll be rocking de party
 THANK YOU!
