solved the problem!!
tnx!
movies not loading
Re: movies not loading
What did you do? Clips that where loading fine now do not. infact nothing loads..?
Like Joris check if one of your MIDI devices is set to MIDI clock and check in the preferences if a valid audio device is chosen. If the beat indicator is running all is fine.
