I really dont understand this file size thread going around on DXV :
i just did a test with the latest DXV 2.1.1 codec ,
in Adobe Premiere Pro CS5 i made a 5 sec file made of bars and tone in 720P format 25 fps
then exported it under quicktime animation jpeg A full quality(closest to Mjpeg correct?) size : 7.78 Mo
the same project exported under quicktime DXV, size 2.91Mo
i then used the quicktime animation jpeg A file in Mpeg Streamclip and transcoded it to DXV:
i got a 1.84 Mo file.
So, unless i made a mistake , DXV files a not really bigger then quicktime jpeg A or Mjpeg???
i compared the files in premiere vectorscope to see if i could find any luminance or chrominance differences, i a didn't find any diffences, except for detail rendering.
anyone else done some basic testing??
DXV 2.1 - crashes in any software except avenue
- rxfromparis
Re: DXV 2.1 - crashes in any software except avenue
desktop: Windows 7 64bit , i7 920 2.66Ghz, 12Gb Ram, GTX 950 2Go, WD Velociraptor 300Go, terratec asio phase 26 usb soundcard & midi,Novation Nocturn controlpad, Akai MPK mini, and soon to come : BCR 2000
graphical content - like simple one colour bars, will produce a much smaller file with DXV than a clip the same length but made from film footage. the people who are not happy with / experiencing large file size are most likely using more film based footage.
- Tschoepler
Soooo true. I'm really starting to wonder about how people want to deal with video if they don't have a minimum of background knowledge. No offenseVJair wrote:graphical content - like simple one colour bars, will produce a much smaller file with DXV than a clip the same length but made from film footage. the people who are not happy with / experiencing large file size are most likely using more film based footage.
[oops: getting off topic]
