You can browse the source code in the link given in the blog post,
or download the FFGL openframeworks addon that contains also the source code for the plugin here :
http://code.google.com/p/ofxffglplugin/downloads/list
Resolume Christmas Present 2010: FFGL Fireworks Plugin
Re: Resolume Christmas Present 2010: FFGL Fireworks Plugin
I don't understand how to start working with plugin like this.
I do see this plugin in the sources folder but when I copy it to the other video clip, it's just replace it.
So, do I need to add lines or something like this?
How does this animal work?
Is anybody getting an issue with this plugin on Arena 5? My Log file says:
Load plugin: C:\Users\Owner\Documents\Resolume Arena 5\FFGL Plugins\FFGLFireWorks.dll
Load failed
Load failed
You'll be missing some dependent DLLs. Possibly MS VC runtime, Free lib or zlib.
Well, really red in the face now. I have tried to copy those back over a few times... My actual problem?
I forgot that Fireworks is under Sources and not Effects.
Thank you for the help.
Any chance this one might be updated for 64 bit? I loved this Fireworks and the Snowy effect.
i followed the .txt instructions and nothing shows up in resolume
I'm taking a stab at getting rid of all the openFrameworks crud in Fireworks and now I'm crying.Any chance this one might be updated for 64 bit? I loved this Fireworks and the Snowy effect.
This plugin is 32 bit. Resolume 6 requires 64 bit plugins.i followed the .txt instructions and nothing shows up in resolume
Thanks for having a look at it as I am sure there are many other pressing things. I can only imagine how different things were 7 years ago. Any help you can offer is greatly appreciated. I owe you one if you are ever in the US regardless of outcome.
I ported Fireworks to 'normal' FFGL and added the source code to the repository on Github. FFGL is pretty powerful.
Just interested in the 64 bit plugins? Downloads are here: https://github.com/resolume/ffgl/releases/tag/fireworks
