2+ blackmagic intensity shuttles ?
massta
Re: 2+ blackmagic intensity shuttles ?
Post by massta »
Are you guys using it like Vade does here?
http://vimeo.com/6021703
Wondering how smoothly it connects now that it has been around a while.
asperi
Post by asperi »
massta wrote:Are you guys using it like Vade does here?
The Matrox MXO2 works. I had one working on a PC with the Intensity shuttle, mixing the two in R3. The issue is that the MXO2 had too much delay, almost a 1/2 a second or more, that did not work for me. With the shuttle the delay is only a frame or two at 1080.
massta
Post by massta »
Maybe the Intensity Pro with its PCIe connection directly to the motherboard would be the way to go.
Of course, a dedicated PC to mix the signals is needed. It would probably be too much for the machine to process Resolume as well.
http://www.blackmagic-design.com/produc ... ty/models/
Tecno`
Post by Tecno` »
I have just installed an Intensity Pro in my machine and am very impressed!
There is minimal lag and the quality is great.
Tim
