Connect artnet grandma on pc
ASP1978
Re: Connect artnet grandma on pc
Post by ASP1978 »
Hello
No I don't have a network switch.
I use the 192.168.1.1
I did tried to disable the wireless network but still no luck.
I am using Resolume on a MAC so I can not use the DMXWorkshop unfortunately
Is there anybody else out there who made GrandMA work with Resolume?
drazkers
Post by drazkers »
In my experience with artnet on various boards (Chamsys, Jands, MA2), you must have a router set properly. I've found in the past with MA you need to have 255.255.0.0 for your subnet. 255.255.255.0 and 255.0.0.0 have had a history of not working for me randomly.
Mikeymo16
Post by Mikeymo16 »
did you ever figure out a solution. i'm running into similar problems and there is very little to read concerning the Gma2 and resolume :?
