Output Test Card
dirtyjohn_lv
Re: Output Test Card
Post by dirtyjohn_lv »
Curious as to why you consider these "pro" solutions (legitimate question). Is is because they're from a media server? Having been a projectionist before (worked with a wide range of equipment, mainly Barco equipment). 80% of the time, we would use internal test patterns to blend and overlay images (I do realize that isn't a viable solution for all systems).
vj granda
Post by vj granda »
Hi dirtyjohn, I consider the test cards from Cosmowe more pro because there are more patterns and resolutions, and specially the Edge blending ones, that's what I was looking for, and what I would like to see in Resolume 4. Your test card is Pro, too, but may be imo, It's more focused on setting up the projector, and the first post is talking about a test card to do Edge Blending...
GuruMeditation
Post by GuruMeditation »
I found this :
http://alex64.free.fr/Mire_1024x768px/Mire/
Maybe a test pattern with several options we can activate/deactivate is possible (color/phase/gradient/softedge... etc)
For the test pattern I did a loop with several pattern, it is more flexible and it fit to the resolution I work with.
SystemD
Post by SystemD »
A lot of pattern in this website :
http://www.walvisions.com/TestPatterns.html
@systemD:
nice side!
