Avenue 4 MIDI Output
justints
Re: Avenue 4 MIDI Output
Post by justints »
Bome's is great! Using the midi map from Behringer and Bome's, it is actually quite straight forward to get your buttons to toggle to any of the colors available. You can use very simple conditional statements to translate resolume's return velocity to whatever you would like to send back to the controller.
It is also straight forward to scale resolume's slider outputs to the controller's encoder LED indicators.
I found a GREAT best-practices guide by "metastatik" to Bomes in their forum.
Parts 1-4:
http://www.bome.com/forums/viewtopic.php?f=3&t=5049
http://www.bome.com/forums/viewtopic.php?f=3&t=5051
http://www.bome.com/forums/viewtopic.php?f=3&t=5052
http://www.bome.com/forums/viewtopic.php?f=3&t=5053
bobsj
Post by bobsj »
hi, can any of you lovey ohm rgb users confirm that the rgb led's dont play nice with resolume out the box?
im struggling onstage without a clear indication of where my loaded banks are (no lights on my block, only activated clips)
some banks have a few clips, some a shed load, i need a visual reference on a dark stage of loaded clips,
counting buttons across in the middle of a show to hit the right cue sucks and i more often than not get it wrong (duhh)
any other recommendations of controllers that have feedback on the led's apart from the apc40 with bomes?
thanks
bob
