Interesting, I have a Sapphire HD 7970 causing crashes on startup with Arena 4.0.0, 4.0.1, but not Avenue. In Win 7, usually crashes the whole machine.
Haven't had time to play around with it, but there might be a couple of eyefinity related settings to watch out for?
									3 Slow GPUs running 5 Screens
Re: 3 Slow GPUs running 5 Screens
anachphronism/neologasm.
Hi guys,
I have spend the last 5 days doing tests with arena 4.1 and my gpu. Todas i found a good result for low frase rates and crashes due to gpu load.
And the solution is: overclock.
I was running tests with 3decks with 12 layers of dxv videos some of them have Rgb effects in a 1280x720 composition.
When I connect 10 of them the gpu load goes to 78% in my gtx 460m gpu monitored with gpu-z.And after 22 minutes the sustem freezes and reboot. This happens with the latest driver and clocks of 675 and 750mhz for gpu memory. My frame rate was 19 fps when avanced output
Then i installed the beta driver 304.97 and overclocked to 800 mhz and the memory to 1500mhz with ntune
Then finnally after 5 days of testing things goes stabble with 40fps with same clips as before
I expect this could be a learing for us:
Arena Needs good gpu to work and if they could be overclocked better results could be achieved in certain conditions.
That doens't work either.
The crash continues.
