Application default problem
Re: Application default problem
This is now a known bug, which will be fixed on the 4.1.3 release. In the meantime, saving the comp and then quitting and re-opening Resolume will make the clip play back correctly.
Okay, thank you for information ... i'll try it this way
Yes,correct,suggestion works..I also have this problem,but only with music videos.Only videos works perfect.After 2 hours experimenting i found it myself
