Check out the Pixell VP-x4xx series of graphic expansion modules. You can go upto 24 outputs in total
http://www.pixell.com/vp-x4xx.htm
Question: 6 outputs to projectors + 1 monitor on Mac Pro
arindamliveguitar
Re: Question: 6 outputs to projectors + 1 monitor on Mac Pro
arindamliveguitar wrote:Check out the Pixell VP-x4xx series of graphic expansion modules. You can go upto 24 outputs in total
Like how all the images are for a datapath x4. Is this like a chinese clone in a bigger rack space or is the web designer just lazy?
They are just lazy. And yes, the 4 output model is just a Datapath x4 with a shitty sticker on the front. I can't speak to their larger models though, never worked with one before.drazkers wrote:arindamliveguitar wrote:Check out the Pixell VP-x4xx series of graphic expansion modules. You can go upto 24 outputs in total
If you are looking to buy an x4 in the states, I would recommend Dynye as a source. Ask for Nathan Nye: 215-886-4328.
Pixell is ok, one of the x4 units I got from them was DOA however.
