Examples of a few good things about 2.0:
> Adding the Layer Blackout buttons is ingenious.
> Like wise the "Time Switcher" transition, which is effectivally a strobe effect
> Interface is ultimatelly even clearer to read and navigate through
> There are indeed a lot more control options that make the software even more versatile.
On the whole and for now -- WELL DONE.
GuyKo.
Resolume 2.0 final - Place your bugs here...
Few more potential bugs
Have a look at the following, think they might be "oops":
> Behaviour of Effect parameter bars are very irratic: they don't seem to "move" when Effects are loaded and ran in the centre Window only but do run on the top and bottom ones, other times they only run on either top OR bottom etc.
> Chaos: although configured to use only Deck no1, when other Deck tabs were selected, Chaos uses them anyway.
> "Save Deck" button bellow Preview: for some reason seems to work only with RIGHT mouse-click not the usual LEFT-click.
> Layer Opacity sliders: compared to V1.51, is it possible that when using the keyboard shortcuts, their travelling speed from 0-100 is slower in V2.0? Does it have to do with system resources, i.e. the more clips running in Layers 1-3, the slower the response of those sliders will be?
Anonymous
Resolume does not record more than about 5 minutes of video. Is this because it doesnt generate OpenDML compliant files? I mean the limit is less than 2Gb so I guess this is the problem (tell me if im wrong), and it gets tricky when one wants to record a demo, for instance... For my 20min demo I had to re-press the record button 3 times and later edit all the thing in Premiere to place my logo to cover the 2 or 3 second gap between each file (because I wanted it to be sound synched).
Is it possible to solve this prob in a future version?
Cheers!
Cheers!
Anonymous
Record speed is 25%+ faster then the original mix, when trying to put the original audio under the mix this made quite a problem. Tried to compensate within premiere with duration, but the test render (running now) will probably be shocky. This item has been on the board several times, is this on the fix hotlist?
Haven't really had a problem until now, because I mostly record to DV, which generates a 1:1 copy of the mix speed. Didn't had the DV around so I tried the recording function. Is there a trick with the fps?
Cheerz.
nz|sense
[Edited on 19-1-2005 by Sense]
Cheerz.
nz|sense
