Hi Folks
Right click on a clip on the deck, select Bpm, then set direction to backward.Select the clip to play on a layer: it plays forward.
This doesnt happen with the other transport controls. But you knew that didn't you?
That aside: 2.4 Love it!
Shuttle SN25p
Athlon 64 X2 Dual Core 4200+
2 Gig Ram
Geforce 6600
2 x Samsung sp250
Running Avi (PICvideo M-Jpeg 3 VFW ) & Mov
[Edited on 16-8-2006 by PhoticSR]
Post your 2.4 beta bugz here
bypassing effect slot with the mouse/midi controller doesn't work properly- it always works when we use the midi controller, but sometimes when using the mouse we have to click two times, as sometimes the effect slot is highlighted like it was bypassed but it's actually not, and vice versa. it's seems that the midi controller doesn't react to the actual highlighting (bypassed/not bypassed) of the slot but only changes the state (like expected), while changing it with the mouse corresponds to highlighted or not, even though this highlighting is false sometimes....dunno if this is understandable, sorry....
