also i can't link a shortcut key from the keyboard to Lk and At
Resolume 2.1 problems
Mmm, can't get 2.1 stable
3 hour (gig) launch party of crazylove.nl.
1 crash on trying to adjust parameters with mouse in layers, often use midi, but this time there was no room so had to fall back to mouse.
resolume just disappears
Don't want to go back to 1.51, cause the lack of preview, but it crossed my mind :/
Any short patches coming on schedule?
Cheerz!
Cheerz!
Cheerz!
Cheerz!
I 'm experiencing really big problems with more complicated Flash films in R2.1.
Those movies using intense programming were running in R2.0 and they still do.
In R2.1 those movies seem to run in the background, only their output is frozen.
I see this when i reassign them to a layer repeatingly. Than i see a progress, so they must be running, only the output is frozen.
This happens only with timeline control set to "flash". Some more easy clips have the same prob, but if i set them to "resolume", they work. But i can not do this to the more complex clips, those don't work with "resolume".
Unfortunately is R2.1 completely useless for me without these clips R2.1.
I case you need an example, i've send one clip to bart. In a flash projector or browser (or in R2.0...) you can see how it should work.
