No output on 2nd screen !
GeeEs
Re: No output on 2nd screen !
Post by GeeEs »
:) Jup... Working now! (also 7600GT here)
Thx for the tips!
Problem: No output on 2nd screen. (mainly NVidia)
Solution:
Start NVidia configuration panel and go to manage 3D settings.
-NVidia 3D config panel won't show Avenue.exe in the 3D application list, also it won't when you press [add] and navigate to the folder, probably [C:\Program Files\Resolume Avenue 3 Beta rev990\], but when I started typing Avenue.exe it appeared in the dropdownmenu !!!
-Create a profile for Avenue.exe by following the steps gpvillamil described:
[set the Multi-Display/mixed-GPU acceleration to Compatibility Performance Mode]
That's it! Both Windowed and Fullscreen output on 2nd screen working!
Note !! For me, this solution only worked out with Omega driver.
[edit] hehehe.. crossed post.. Thx Edwin and Bart also for this workaraound!
nowig
Post by nowig »
Thanks guy's it work perfectly :D :D
stadtkind
Post by stadtkind »
thanx a lot it is working!!
but i need a faster machine to use triple head 2 go ;-) :?
hobbyboy
Post by hobbyboy »
Hi All,
GP where would we be without you!! Thanks a lot..glad you are still around.
Avenue looks great, well done guys..
HB
glasshopper
FIXED Re: No output on 2nd screen !
Post by glasshopper »
yeah good workaround - thats more like it.
Tx.
Refekation
Post by Refekation »
Works like a charm.
AWM
Post by AWM »
Hi, my NVIDIA control panel doesn't have these options?
Under manage 3d settings all it has is an option to apply presets to specific programmes and Resolume isn't in this list???
GeeEs
Post by GeeEs »
alexwilding wrote:Hi, my NVIDIA control panel doesn't have these options?
you can add all ".exe" files ... read my post on top of this page.
casnl
Post by casnl »
I added the Avenue.exe and performed the settings as you described, I have the Omega drivers, but... is still doesn't work! Avenue crashes when I set my output to the second display or even select it :? I have a 8400M GT.
VJzoo
Post by VJzoo »
I have an ATI mobile card on my lappy and i had to use mobile modder to get R3 to run.
i told a friend with an nvida card to try http://www.driverheaven.net/nvmodtool.php and it seemed to get his output working, it might be worth a shot if you have a mobile nvida card. :)
Jas
(the dyslexic VJzoo)
http://vjzoo.com
~ quite nice visuals ~
