DXV codec.... very impressed!
scottvjguy
Re: DXV codec.... very impressed!
Post by scottvjguy »
Agreed !
DXV rocks . Last weekend I performed at an all night Psy Party in Toronto using all newly rendered 720p clips on twin LCDs . I wish the TVs were bigger but the images looked fantastic.
I dont know if it has anything to do with the codec but the FX are amazingly fast too, Avenue just kept pumping out a smooth fps as I loaded in layers and effects all over the place. It allows me to go so deep I nearly got lost in there.
:D
andrei
Post by andrei »
Yes the best thing in 2009 is DXV codec, my vote :D
The only dab is the rendel time, in ae it is so slow that i have doing like this.
I rendel quiktime whit out any compress by none and in MPEG Streamclip i codec the file, this way it is fast.
I dont know if MPEG Streamclip codec dxv faster but it feels faster.
I like to see that boys in resolume make dxv Batch Export Utility like livid.
Livid Batch Export Utility has same problem like ae it is slow, and i just made 1200 quicktimes in dxv and in my macbook pro it was take 2 days 8-)
I dont know way in my mac pro the livid Batch Export Utility is not working so i have to made in the book pro.
vj hash
Post by vj hash »
Hi, i'm very impressed by the performances of the dxv codec.
Maybe is one of the best innovation, along with the audio, of R3.
Now i can handle 3 layers in full hd.
Bart could you please tell me if the codec uses a lossless compression?
XPSP3 - Core2 Q8200 - 8 giga - 9800GT - RAID 0
punkcake
Post by punkcake »
bt how do you get along with this codec that is so slow.?
i have read also that with this codec there wont be crashing of the resolume. But it still have in my mac book pro 2.16ghz 2gb ram. what could be wrong? resolume 3.
vj hash
Post by vj hash »
Could please anyone answer to my very easy but important question :
is the dxv compression lossless ???
vj hash wrote:is the dxv compression lossless ???
No, it's lossy, if you want lossless compression you can use "uncompressed".
tyco
Post by tyco »
DXV doesn't happen to support an alpha layer/Millions of Colors+ does it?
HerrNieDa
Post by HerrNieDa »
not yet!
edwin
Post by edwin »
We are working on the DXV alpha support. The tests look promising.
So DXV with alpha support is on his way.
gradek
Post by gradek »
vj hash wrote:Does anyone knows a software that can batch quicktime file as virtual dub do?
sometimes i use sorenson squeeze but the dvx codec is not recognized by sorenson squeeze.
thank you in advance.
F.
I have tested several, Livid Export Utility is free and seems to work fine. Apple compressor also works good for DVX. Adobe media encoder gave me glitches when encoding DVX files. More info about that here:
http://www.resolume.com/forum/viewtopic ... 730#p20730
