Hi everyone.
Just wondering if this patch will work with latest version of Resolume?
I have tried it to check out how it works and couldnt get the clips to launch even that I could see them lighting up and switching in resolume... but just no video on the outputs
Any ideas of what I am doing wrong?
Chaos Mode for Resolume Avenue and Arena 6 - Max patch
- gpvillamil
Re: Chaos Mode for Resolume Avenue - Max patch
Yeah, it should work fine. I've tested with the newest versions. Make sure your opacity is turned up on the videos.
disflux wrote:Hi everyone.
Very nice, thanx
PS: Friendly suggestion: Have you thought to creating a webpage for your 3 creations or does one already exist (for consolidating info, that is, if you want to publicize more) ? I was not aware of each Max pgm until fully reading throughout the threads which takes time and could be possibly missed.
2013 - Present: Dell Inspiron 7720 laptop, Win 7 sp1, Nividia GeForce GT 650M
2008 - 2012: Dell Vostro 1700 laptop, Win XP sp3, Nividia GeForce 8600M GT
2004 - 2008: Mini PC ITX...
Official Website: http://www.juliemeitz.com
Hi
I cant get the copilot to work
I am using windows 7 64bit
areana 4.1.3
and have downloaded version 7 of copilot.
I have installed max runtime 6.1 and load the file. Copilot looks like it is working but resolume does not appear to be repsonding in any way.
In resolume I have gone to preferences > OCI and enabled both inout out output.
Input is set to port 7000
output is set to 7001 and address 127.0.0.1 with bundles enabled.
is this correct? any ideas would be appreciated
areana 4.1.3
Update, I installed the Step sequancer, and found I could get this to work if i unticked "Bundels"within the step sequncer software.
Copilot does not have this "Bundels" tick box to untick tho.
Any ideas?
Any ideas?
Hi!
Anyone know how to install on a PC? Doesn't seem to know what to do with .maxpat files..
- gpvillamil
Updated to version 2.0 which supports Resolume 6
I know Autopilot does a lot of this, but I find it useful to be able to switch off the auto triggering in one place.
Re: Chaos Mode for Resolume Avenue and Arena 6 - Max patch
Hello. Is there any plan to release this and the Step Sequencer for Resolume 7?
