Slow reaction from controller?
gbravetti
Re: Slow reaction from controller?
Post by gbravetti »
CCs that produces bottle-neck.
Other CC/Channels seems to be OK
Strong cc 1 ch 1
Strong cc 2 ch 1
Strong cc 3 ch 1
soft cc 14 ch 1
soft cc 15 ch 1
soft cc 16 ch 1
soft cc 20 ch 1
soft cc 21 ch 1
soft cc 22 ch 1
Strong cc 30 ch 1
Strong cc 31 ch 1
Strong cc 33 ch 1
vincentoliver
Post by vincentoliver »
THANKS SO MUCH!
vincentoliver
I spoke too soon. It's gone slow again. I hate Resolume.
vj granda
Post by vj granda »
vincentoliver wrote:I spoke too soon. It's gone slow again. I hate Resolume.
You are the first person I hear to hate Resolume... What version of Resolume do You have? And what specs in your system?
gbravetti
Post by gbravetti »
vincentoliver, can you list the CCs/CHs you are using now?
vincentoliver
Hello
I was being flippant and joking a bit in my last post. I'm generally really impressed but there are areas that I felt held me back. I did my first gig using Resolume last night and it was a disaster for me. Mostly because of the controller problem but also that it's extremely difficult to do things manually when your controller stops working. On a 13" screen, I could really do with some flexibility over how things are laid out.
@vj granda: My machine is a 13" Macbook Pro 8,1 with 10GB ram and a 7200rpm hard disk. The Resolume version is Arena 4.
@gbravetti I literally tried every MIDI channel and most of the controller numbers (on a nanokontrol 2). I made sure I avoided the ones in your list at first but eventually found that no combination of channel/CC number worked well except for a short while after changing them. Then it all went slow again. REALLY slow.
vincentoliver
Thanks for listening guys. :)
gbravetti
Post by gbravetti »
vincentoliver,
do you have any sequencer application there with you? like ableton live or similar?
vincentoliver
Yeah, I've checked it out on ableton and it seems fine.
gbravetti
Post by gbravetti »
ok, just do this, play your controller though an Ableton MIDI track, you will need a virtual MIDI device to connect Ableton to Resolume, then record your performance, then play and check if it behaves the same, then send save and send it to me. gbravetti@gmail.com
