Datapath Fx4
jaydeeshow
Re: Datapath Fx4
Post by jaydeeshow »
Hi Speedteam,
your question is pretty broad, I f I understand your question:
Use (windows) wall designer to program the edid of the FX4. Once did that, connect a cable from the fx4 to the macbook and in advanced output you should see a big screen i.e. 3840*2160 if you have programmed the edid to use 4 screen/projectors.
I hope I answered the question.
Best,
J.
1norbertos
Re: Datapath Fx4
Post by 1norbertos »
Hello ! ;)
Sorry for my english, i am a hungarian musician/manager.
I have a datapathx4 .
We using 6 Led Tv (Full Hd each type)
We using a Hdmi splitter too.
Laptop Hdmi output –> sign to hdmi splitter in (with hdmi hdmi cable) -> sign to datapath in (hdmi-Dvi cale)-> four tv (2 Toshiba 48L644D TV and 2 Toshiba 48L344DG TV) (one picture on 4 tv) with DVI-Hdmi cables
->two separated tv (with hdmi hdmi cable) 1 tv 1 full picture 1920x1080
We have some problems :
-sometimes we have some green lines on four Datapath tvs (The 2 separated tv-s (from hdmi splitter) sign is ok,never green lines.
-if the datapath DVI in cables moving about 0,3mm -> not working
How do we fix this problems ? Please help me,we tryies many cables,but we noticed : no change.
Thank you ! ;)
jaydeeshow
Re: Datapath Fx4
Hi Guys,
Finally, I had some time to play around, and I've noticed a new WD software 2.1.0. Because I've recently updated my GPU, now 1080Ti Asus turbo (base clocked) I'm trying to program the EDID with 4 projectors 1920x1200 one beside the other. Creating an input of 7680x1200 at 60hz. Is connected with DP 15'. I've applied and no warning, pretty surprised I went into the display, and it sees it as a 1920x1080. I decided to go old school and create a 3840x2160 at 60hz and still nothing. The cable is obviously too long. Switched with 3' and sees the 3840x2160 at 60hz. I wish I could say it recognizes the 7680x2160 or 1080 at 60 or 30hz because it doesn't. We know how to get around with the 3840x2160 but lately using mask and blending could be tricky sometimes.
Just an update.
Have a great day everyone.
ps. I've switched to PC and hoping to use an Egpu with my 2014 MBP 15"... now Wall designer is available for MAC OS (10.12). It was about time.
