wishes for new version
tom_
Post by tom_ »
i read about a tool called Freechain that will allow you to chain two plugins together. cant be arsed to google for it though:P
malco_
Post by malco_ »
is an avs reader even possible?
I'd be dead keen if it is
Freechain is an application that can link multiple freeframe plugins and recompile them to a new plugin. It,s a great tool made by Pete Warden. You can find it in the big freeframe zip file here: http://sourceforge.net/project/showfile ... _id=191375
malco> what is an avs reader?
videoteque_
Post by videoteque_ »
AVS>> Advanced Visualization Studio, the presets of Winamp.
It would be great if someone created a plug-in that can "listen" to line-in and render AVS presets inside Resolume.
malco_
Post by malco_ »
That's just it bart, I don't know if such a thing exists. Just at the moment i have to go through all kinds of rigmarole to convert them to avi.
that thing that videoteque suggested would make my life complete.
creating an avs reader wil be very difficult as the plugin API does not provide a canvas on which the pluging should paint it,s visisuals ... every plugin creates it,s own output window, so grabbing the visuals is different for every plugin ...
ST-V (stark)_
Post by ST-V (stark)_ »
i ve got a new one..
i want a video clip cutter... currently you can cut the time of a clip moving the little bars on the edges.
but it would be great to sync a clip to beat. so that for every one, two or 4 beats its starts over, how to do it?? have the option to set the start and stop points with the keyboard.. or set the start point with the mouse for example. click enter to start playing and enter to cut and loop.
anyone up for it?
battagliero_
Post by battagliero_ »
A MAC version!
cat_
Post by cat_ »
How about right click on a layer thumbnail to pull up a menu ala the clip menu with brightness contrast and tint controls? I'd love to be able to stuff, I use quite a lot of monochromatic stuff but it would be great to be able to colour change them live! Especially midi controlled!
Id quite like to be able to click in the timeline to return the counter to where the mouse instead of moving the mouse to the counter.
Oo wrong section but I've found a bug, I can assign shortcuts to the keypad they are saved but when resolume is relaunched they dont work and you have to assign them again
