AKAI APC 40 and Resolume Avenue
Re: AKAI APC 40 and Resolume Avenue
thanks for taking it down btw.
no need to thank -- thats super embarassing-- I pm'ed you i think
Joris, I take the word ... A template for the Apc 40 would be perfect...goto10 wrote:I
As for the current state of things, this is coming along swimmingly. When the new release drops, we'll also be putting out templates for the most common controllers, including the APC40.
Hope that explains it.
thanks
Are there templates with R4 or the last version of R3?
Just bought the apc20... wow...
@basic:
And now you just have to buy another APC40 an screw them together.
Do you like outlines? Easy Outliner on Juicebar Re: AKAI APC 40 and Resolume Avenue
hahaha, i seen you post that before... that is mental!
I'll get to grips with the one first... then we'll see where i take it lol
alfaleader
Hi
I made a program to extend the possibilities of a controller with processing. (based on java). It features different banks and a fader mode, and lots other cool stuff.
When you know your programming basics you can make your own program that suits your needs!
http://vjforums.com/showthread.php?t=37 ... processing
- Yuckfou157
Hi All...
At first, I'm very very new to midi and trying to get things work....
Then, I have installed Cozer's and others workaround to get my APC40 working with Arena but it's getting stuck on a particular problem...
When I use only the midi mapping file from Cozer everything works as planned except of course for the lights on the APC, I have MidiOX, Midi Yoke and Bome's translator, and followed the instructions previous in this thread, yesterday evening, working with bome's trial it worked fine so I bought the program, de-installed the trial and installed the pro-version, since then, my Arena freezes whenever I try to get the setup running, and it seems like bome's is the evil in-between, so I uninstalled the pro version and went back to the trial but it still freezes Arena and I have to close it in task manager to start it up again, then when I close all the midi-help programs, set Arena to default APC in/out it works again with Cozer's map and when I try to get the midi-helpers back in it freezes again...
When I try Assembler Surface it works, but it doesn't do the thing for me and I don't know how to programm it to my wishes where I can alter Cozers map for my own needs...
Any of you an idea what I'm doing wrong?
