Hi. i would like to ask you something:
1st I am using resolume on my notebook and on a monitor. when i set the DUAL MONITOR, then i see the "movin´pictures" only on the second output screen (not on notebooks screen). IS IT NORMAL?
2nd what do i need on my notebook if i want to use a video PROJECTOR (dont know if this is a correct word, it allows you to display graphics on a wall)
THX
wishes for new version
think about adding in resolume those features:
-to can load a audio-video clip in the deck. so to can have (remember coldcut vjamm) an audio out from a videoclip. the audio out from resolume can go into the dj mixer who can open the audio from the video in resolume. i find the audio out from resolume even more interesting than the audio in for bpm sinchronization. cause one of the funny things to reach in a live is to get the bit "manually".
- i like also the idea to can point frames inside a loop, and then for istance randomize or juming between those points. (vdmx software for mac can do that, and even navigate those "keyframe" on time with music)
- resolume could be more complete adding some features about swf files as in vjsfware based on flash only (vlight, flexer...)
-keep resolume in a low profile like it is. i mean not give them too invasive and pre-packed effects as in arkaos...
others ideas will come.
when is the new release going out? will i need to buy it or i'll use the same serial i had paid before?
nice job guys.
pis&low
noce
nice job guys.
pis&low
noce
one problem with resolume is with the dual-view. when i put the 2nd monitor (the projection) and want to change to 800x600 output it most of the time put it on the 1st monitor (laptop resolume running). i have to try 3-4 times to get this right. is this a bug? or do anyway have a trick how to make this. pretty frustration when i had to restart resolume and try to get the 2nd monitor on the canvas. all this live.
