AKAI APC 40 and Resolume Avenue
Re: AKAI APC 40 and Resolume Avenue
Not to discourage anyone from creating their own Bomes setup, but just to let you know since Resolume 4, midi feedback is supported out of the box for the APC40. There's no need to use Bomes, unless you want specific functionality (different colors for layers or the like). If you just want the playing clip to light up, or feedback for your dials, Resolume does this for you.
The new midi out feature is great but its not extravagantly great (this is not a discredit to the Resolume team they've done more on this issue than they need to imho). But unless there becomes available some options to customize what the midi out can do I think there are many of us that will stick some form of secondary midi out.
Yuckfou157 I'm not completely sure whats happening with your setup but if you pm me maybe I can help you out
_Cozer
_Cozer
theLABVisuals
I think I'm getting closer to having the APC mapped via bomes as I want.
Tony_Blend wrote:I think I'm getting closer to having the APC mapped via bomes as I want.
That looks really awesome!, I need to start messing with my APC 40 again.
- Vjcheshire
Not sure if this has been covered in this thread (or in other threads) but looking for a way to easily *shift* the keys for the apc40. By shift I mean Bump all the midi numbers/notes up on the apc40 with a single click and have them already mapped in resolume so I can use the same buttons, but do different functions on the fly. Trying to minimize the amount of controllers I have to bring to an event.
theLABVisuals
I'm currently implementing on my Bomes patch the facility to switch the midi data out to madmapper (presets) as well as switch back to Resolume as an when I want (aiming to save a seperate controller setup). I think the best approach would be to script something yourself within bomes based upon a preset activation.Vjcheshire wrote:Not sure if this has been covered in this thread (or in other threads) but looking for a way to easily *shift* the keys for the apc40. By shift I mean Bump all the midi numbers/notes up on the apc40 with a single click and have them already mapped in resolume so I can use the same buttons, but do different functions on the fly. Trying to minimize the amount of controllers I have to bring to an event.
Sounds good Tony, I need your help with Bomes sometime soon if thats cool! - I still need to get the APC20 working to my likingI'm currently implementing on my Bomes patch the facility to switch the midi data out to madmapper (presets) as well as switch back to Resolume as an when I want (aiming to save a seperate controller setup). I think the best approach would be to script something yourself within bomes based upon a preset activation.
theLABVisuals
I've got a rough idea on how to make it work with Res3, it's just getting the time to do it without faffing around with midi splitters or the such like (bit of a rewrite on the variable front). Keep you posted though squire.Basic wrote:Sounds good Tony, I need your help with Bomes sometime soon if thats cool! - I still need to get the APC20 working to my liking
cool, also some general help in workflow with bomes would be great. I just need to pick your brains at some pointTony_Blend wrote:I've got a rough idea on how to make it work with Res3, it's just getting the time to do it without faffing around with midi splitters or the such like (bit of a rewrite on the variable front). Keep you posted though squire.Basic wrote:Sounds good Tony, I need your help with Bomes sometime soon if thats cool! - I still need to get the APC20 working to my liking
Hey all
Quick question, just bought myself an apc40 and I tried the mapping/bome file from you Tony, works fine with just 'bome'
Now I tried the files of Cozer and they shouldn't work without the 'midiox', now because of the midi in&out features in the latest arena everything does seem to go well more or less with 'bome' setup in the same way as Tony's file (midi ports activated) and with the apc set to generic mode instead of alt ableton. Is this possible? Oh and something else, there seems to be a 'play only when button is down' function activated in resolume how do I set this off?
Thanks in advance, Matt
