wishes for new version
_
Post by _ »
Also I'm with lucid on a quick tab to swap decks, if you have a few machines under contol then trying to browse new decks on several comps is a right pain.
Maybe even make it available to skip to next deck in library on a midi trigger, or set up a keyboard shortcut to say decks 1-10.
Aren't we a pain, all these demands hehe. You know we all can't live without resolume...
piXelstar_
Post by piXelstar_ »
An .INI file to set the starting parameters, like default directory, thumbnail view on/off, output resolution, etc..
themadhatter_
Post by themadhatter_ »
word!! pixelstar is absolutely right on that one...
espescially starting directory modification would be great!
maybe some kind of preset editor could help...
Anonymous
Post by Anonymous »
Video to Flash Converter is an easy to use program for converting your AVI digital video to SWF Flash format. You do not need any special programs or plugins to create SWF video file, simple select and convert Video to swf Flash file.
http://www.geovid.com/Video_to_Flash_Converter/
gpvillamil
Post by gpvillamil »
Chromakey! I have *lots* of footage of dancers against green or blue screen.
