Hello Res Team,
it would be very nice when the recording function would record the Output composition and not the advanced output comp - else clips are recorded with the mapping settings and they become useless. While I write this I recognize that I almost record no clips anymore because I can't use this cool feature properly.
Thx for listening,
Ben
													Recording output NOT ADVANCED OUTPUT - *SOLVED*
- Bang Boom Ben
b
						b
Re: Recording output NOT ADVANCED OUTPUT
I'm confused. The recording feature does record the composition output before the advanced output is applied.
						- Bang Boom Ben
OK. You are right, is this new ?? Didn't check since last time.
b
						b
