"On Screen Capture Recorder" Problem
BPM
Post by BPM »
I tried the "on screen capture recorder" you recommended over previous posts,
(http://sourceforge.net/projects/screencapturer/)
It is not working with resolume on my Win7 64.
It is shown in the source window but gives black screen and doesn't get the resolution info from it.
With other VJ software on the same computer it is working great.
Any workarround?
10x!
vj granda
Re: "On Screen Capture Recorder" Problem
Post by vj granda »
I can't find any post in this forum, talking about "On screen capture recorder", except yours...
BPM
Post by BPM »
here is the post where edwin reccomended about this software:
viewtopic.php?f=12&t=10018
vj granda
Post by vj granda »
Yep, I see now. It's impossible to find the post with the forum search...
It looks interesting, but quite difficult to work with... Have you tried with another Directshow?...
BPM
Post by BPM »
Other Directshow works, but the "on screen.." is very stable and is exactly what I need.
edwin
Post by edwin »
I did a quick search last time and found that 'On Screen Capture Recorder', it didn't seem to like my system either actually. So you might try to find something else, it's a bit of a search to find something that works properly.
